Artifacts Light Bleed
samsue
I am having this problem that I cannot find the cause
paride4331
Hi samsue,
have you any stretched bump or normal map on the wall?
Regards
Paride
samsue
was the Ray epsilon i set to 0,001 this solve the issue!
thanks for response Paride as always
samsue
elsksa
thank you for answering, I really appreciate it!
I could not find the cause of this problem for this specific scene... but I will take into consideration the things you said if it appears again, Thanks
Return to “Autodesk 3Ds Max”
