Manual (ACES)
Maskeline
Hello.
I don't know if I'm looking in the right place, but on the web the last manual there is (for octane standalone) is for version 2020.1, published 1 year ago.
I needed a manual for version 2020.2, to see how ACES works.
Most of the projects we are currently working on are based on ACES and when we try to implement it in our octane pipeline, it doesn't work and we need to know what we are doing wrong.
Thanks!
Maskeline
We use ACES in other software (e.g. Nuke and Da Vinci), and our entire pipeline is structured around ACES.
It is difficult for me to explain what doesn't work, because I don't understand how it works in octane (that's why I wanted the manual)...
Roughly speaking, ACES is a color management system that allows you to have the same preview in all the software that uses it... That presupposes a render color space (ACES 2065-1) and a preview space (in maya in the render view)...
I have not been able to preview in ACES sRGB in octane with maya... And there are several places (with several nodes) where to look.
- In the render globals; where I have even loaded an ACES 1.1 file... config.ocio
- In the imager; There are Ocio look and Ocio view, but I have not managed to connect it well (I guess, because I do not see the desired result)...
In other software there is a workflow document for ACES...
I have only found a Cinema 4D video where it is explained... But the plugin integration is different and I can't configure it.
In conclusion, what I need is a manual (to see how it works and how to configure it in octane for maya and in octane standalone) or an explanatory video with a practical case...
Like this one from Cinema4D
https://www.youtube.com/watch?v=3TU6OeONDcA
BK
Maskeline wrote:Hello.
Thanks!
hi Maskeline,
Apologies for the late reply.
We are currently working on the Standalone manual and will be uploaded sometime this week.
Regarding the render results, would you please share the screenshots here or PM me the render results?
Also, please confirm if the workflow is the same,
- Load OCIO configs from the Octane>OCIO rollout
- hook up the OCIO View and the OCIO look node on the Imager node
- we can load the color profiles from the OCIO view node
- please follow the steps for the render outputs
cheers
Kind Regards
bk3d
Maskeline
Thank you very much for the detailed explanation....
It is working well.
BK
Maskeline wrote:Thank you very much for the detailed explanation....
It is working well.
Hi Maskeline,
Thank you for letting us know it's working well.
cheers
Kind Regards
bk3d
pippojasper
Is this ACES workflow still valid in Otoy version 2023.1.1 22.10?
BK
pippojasper wrote:Is this ACES workflow still valid in Otoy version 2023.1.1 22.10?
Hi pippojasper,
Thank you for the post.
Recent changes due to Maya Render view buffer limitation.
Once we set the Image format to EXR, then the Octane View would work from the *Select OCIO color space* field.
Please let us know if this works!
cheers
Kind Regards
bk3d
Return to “Autodesk Maya”
