Post Processing Not Working
mikegem
Preview or final Post processing not working. If I enable just the post processing pass I can see the effects, but when I go to combined there is no effect. If I use the compositor and combine post layer with image I can see the effect in final render.
Post_Not_Working.blend
(34.04 MiB) Downloaded 297 times
linograndiotoy
You should disable Post Process in the Render Passes. If you keep it on, Post Process will be exported in a separate pass (you don't want Post Process to be also in the "main" pass in that case).
mikegem
WELL ALLLLLLLLLRIGHT!!! Thank You!! :D :D
linograndiotoy
Sure!
Return to “Blender”
