C4d R24 Tons of emission lights (lightbulbs)..loong render
Gr1f2
Hey all,
I've been making my way through various render engines for c4d in an ever-ending search for somewhat reasonable render times for a scene/model I use a lot.
Im on a Mac Pro 2019 16 core with W5700x 16GB and 160GB Ram. So limited enough hardware for the 3d world.
I had C4dtoA down to about 12min per complex frame and have been getting my head around Octane recently to see if I can improve on this. The recent addition of AI light seems to have helped significantly but I'm still around 20min a Frame with 10k samples if I want a noise free render.
There are 4 source lightbulbs run through 4 cloners with a shader effecting the emission for an on/off effect.
So I'm hoping some of you far more experienced people than me might be able to help?
Here's a couple of screen shots....
I can share the file but would prefer DM rather than public.
Thanks for your time!
Gr1f2
Thanks Beppe,
Just getting back to this project now!
I think I have this working on my file. Cloned Light bulbs work.
One thing I can't figure out is how to 'turn off' the light emission with an effector/shader.
Apologies if this should be obvious - relatively new to Octane
Gr1f2
Thanks Beppe,
Gr1f2
Actually I may have figured it out. Emission set to Blacklight with material set to mograph
Great to hear you have solved :D
Hint, you can also use the Instance Color node, and use C4D Fields with a Plane Effector to change the emission color from black to whatever you need.
Here is an example with Opacity channel:
viewtopic.php?f=30&t=77509&p=399667&hil ... ds#p399667
Happy GPU rendering,
ciao Beppe
