Texel Density Shader
halon
Hi all,
Has anyone out there had thoughts about, created or seen a Octane tool or OSL shader that renders or displays the texel denisty across objects in a scene? Maybe as a render pass?
This might be something similar to Unreal's buffer view "Required Texture Resolution."
Standalone or for Maya plugin would be preferred.
Dan
Hi Dan,
maybe I have misunderstood your question, but, what about the InfoChannel/Texture Coordinates pass?
Texture Coordinates - A color-coded image showing a Gradient map based on the direction of the object’s UV texture coordinates.
ciao Beppe
halon
Beppe, thanks for the idea. We're investigating your idea now. Will report back!
Dan
