Render and live viewer don't display the same image
Cristal
I have this problem. The live viewer display the project perfect but not the render.
I made several renders and it failed at some attempt, I try again and it goes ok, and then it stop working forever.
I need this to be done today so please let see if someone can help me.
I uninstall and install cinema 4d, the same with octane, in several different versions. but nothing works.
Its thinking particles with a tracer.
Help please.
1-Test it standard renderer.
2-Check for the effects which require caching.
Cristal
It works baking with mograph!!
Thank for your fast answer
It works ok without baking with cinema 4d standard render.
Thank you
Cristal
Another issue. I'm using a gradient shader on the material, and colors of live viewer and render are different, the same three colors of the gradient but in different positions. It should be any issue with mograph cache. Any idea of what could this be possible?.
Cristal wrote:Another issue. I'm using a gradient shader on the material, and colors of live viewer and render are different, the same three colors of the gradient but in different positions. It should be any issue with mograph cache. Any idea of what could this be possible?.
Any visual info would be appreciated to don't lost the time. No idea what and where do you use. There's two modes for gradient/c4dnoises if you check nodes. Baking or osl emulation.
Cristal
Sure. Just ask if it would be a common issue. I'm going to try solve for myself. Will come back with more info if I can't.
Thanks for the help
