I have 2 important questions
aeteron
I have in Blender set up the planetary world environment and assigned to the planetary albedo the earth texture map with a spherical projection attached to it.
Now, I can't seem to be able to rotate the texture. The only thing I see is the South Pole, or the North Pole directly underneath, even if i attach a transform node (3D,2D, etc doesnt matter). But I want to rotate the earth (planetary sphere) :-D
How can I do that ?
Second, I have only rotating and moving objects, what is better to choose speed-wise, objects movable or scatter ? I don't care about memory.
linograndiotoy
Works here.
Try to use a Spherical Projection with a 3D Trasform attached to the node.
About Object Types, the Auto option works well on Static or Moving object using Transform. Reshapable should absolutely be set for deforming meshes.
Return to “Blender”
