Multiple Render Node versions on one slave machine?
pegot
Can two different versions of the Render Node be active on a slave machine at the same time?
Win 11 - AMD Ryzen 9 5950X
MB: ASRock X570 Creator
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
pegot
Well I guess I'll just install the second one and see what happens...
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
no, you cannot have multiple daemon versions running at the same time.
You need to close the active daemon with CTRL+C, then start a different daemon version.
Under Win and Linux, I avoid to install the daemon, and I stat the version I need with a .bat/.sh file.
Under Mac, install the daemon, then remove the otoy_daemon.plist in hdd/Library/LaunchAgents, and then you can start the version you want with a double click on the render-node app version you want.
Happy Net GPU rendering,
ciao Beppe
