Limit of Proxys
s3d-weyrauch
we have that problem, that an object using a proxy can have only 2000 copies in an AC-file. The 2001th copy won't be recognized as a proxy ("not a proxy").
We have tested it with GDL Parameters and without GDL Parameters.
We have newly very big projects, and we should arrange plenty of lamps and so on. It can't be solved with scatter, we have place them one by one.
Thank you for your help!
David
BIM team leader
Win 10 | ArchiCAD GER 23-24 | Octane Plugin for ArchiCAD
13 Licenses | Network Render over 12 graphic cards
Daniel_Ward
Not ideal I know, but can't you just create a second/third version of the same object lampV1.gdl, lampV2.gdl, lampV3.gdl etc linked to the same proxy file?
Cheers, Dan
+MAP Architects, Christchurch - New Zealand
ArchiCAD 4.12 - ArchiCAD 24 || Octane for ArchiCAD
i7-7700K - Gigabyte Aorus Z270X Gaming 9 - 32Gb RAM - 3x Gigibyte GTX1070 G1 Gaming - Window 10 64Bit
