Cinema4D version 2020.2-R3 (Obsolete stable) 19.02.2021
Hi all,
This is the latest stable build based on stable 2020.2 SDK. Any feedback will be much appreciated. Enjoy it!
Make sure to use a NVIDIA Studio driver with version at least 456.38 on Windows. No driver updates are required for macOS 10.13 (CUDA).
This version supports the new NVIDIA Ampere architecture on Windows and Linux. Kepler cards with compute model lower than 3.5 are just supported on macOS.
For CORE improvements please check the following Standalone link.
This is the matching Standalone: OctaneRender™ 2020.2.
Changes of 2020.2-R3 build
- fix: Update issue with opengl textures
Changes of 2020.2-R2 build
- fix: priority range
- fix: better management for compare direction
- fix: Easier adding/breaking operation for nodes
- fix: Bring back support for old xparticles versions
- New: Enable/disable update buttons for Geometry/Lights/Camera/Material.
- New: Global hold updates command added. Which is for disabling the update controls for all content
Changes of 2020.2 build
- Core changes for AOV and composite texture structures, your old AOV/composite_texture setups will be broken. You can fix these by manually.
- Improvements on opengl/material preview functionality for faster editing with no lags.
- Light Manager(WIP), not completed yet. I kept it for preview purposes, light linking and more will be added on next builds. Access: shift+C, type "Octane light manager".
- Image sequence saving dialog for making faster previews from Live Viewer. LV menu -> File/Export to/Save animation sequence.
- Fix: better embedded gui functionality in node editor.
- Fix for SurfaceSpread object consideration.
- Several minor performance adjustments.
- Fix for some missing help links.
1- Use NVIDIA STUDIO drivers, not Game Ready versions. If you have stability issues try different drivers, some of them could cause instability issues. Make a clean install while doing this to be sure previous files completely removed.
WINDOWS ENTERPRISE BUILD (R15-23)
https://render.otoy.com/customerdownloa ... R3-win.rar
WINDOWS SUBSCRIPTION(Studio) BUILD (R15-23)
OSX ENTERPRISE BUILD (R15-23)
https://render.otoy.com/customerdownloa ... Macosx.zip
OSX SUBSCRIPTION(Studio) BUILD (R15-23)
Requirements:
-You'll need to update your Cinema 4D to latest versions(R16.050, R17.053, R18.057, R19.053, R20.057, R21.115, S22.118, R23.110). Otherwise, the plugin will not work and not appear in menus.
-Nvidia drivers at least Nvidia Studio Drivers(minimum 456.38) and be careful with latest Game Ready drivers which can cause cuda errors. Stay with stable one for you.
-Cuda 9.1 driver for OSX.
ONLINE HELP MANUAL
To use OFFLINE version of manual from plugin
Download following package and extract to Cinema4D/plugins/c4doctane/manual
https://render.otoy.com/plugindownloads ... p-html.zip
V3 SAMPLE SCENES SET(make a request if you need any specific sample)
https://render.otoy.com/plugindownloads ... scenes.rar
See this topic for some partial samples: viewtopic.php?f=85&t=53989
CINEMA 4D TUTORIALS SECTION: viewforum.php?f=87
CHANGE LOG: https://docs.otoy.com/#60Change%20log
Installation
Ex. if you have Cinema4D R18.0, keep only "c4dOctane-r18.cdl64" and delete c4dOctane-r17.cdl64, c4dOctane-r16.cdl64, c4dOctane-r15.cdl64, etc..
Cinema 4D Release 15: c4dOctane-r15.cdl64 or c4doctane_R15_demo.dylib
Cinema 4D Release 16: c4dOctane-r16.cdl64 or c4doctane_R16_demo.dylib
Cinema 4D Release 17: c4dOctane-r17.cdl64 or c4doctane_R17_demo.dylib
Cinema 4D Release 18: c4dOctane-r18.cdl64 or c4doctane_R18_demo.dylib
Cinema 4D Release 19: c4dOctane-r19.cdl64 or c4doctane_R19_demo.dylib
Cinema 4D Release 20: c4dOctane-r20.xdl64 or c4doctane_R20_demo.xlib
Cinema 4D Release 21: c4dOctane-r21.xdl64 or c4doctane_R21_demo.xlib
Kalua
Sweet! Thank you, Aoktar!
C4D 2025.3.3 Octane v1.9.4 // Octane SA 2026.4, Windows 11 Pro, X399, AMD TR 2950X, <<2 X 3090 + NVlink>>, 128 GB RAM, Corsair 1500i - NVIDIA SD 610.62
Octane User since V1 Beta
pocketcat
octane spot light bug
Kalua
Hi, Aoktar
Small Bug I found until now: every time I close the node editor window, C4d (R 21 and 23) freezes and I must restart it.
Regards,
Kalua wrote:Hi, Aoktar
Regards,
Thanks for reporting! I've fixed, replacing the download links with that!
iDlart
before there was a checkmark so that the denoiser would affect the beauty pass.
Where can I find it now?
iDlart wrote:before there was a checkmark so that the denoiser would affect the beauty pass.
You cannot use it anymore with sRGB color space.
SSmolak
With this version I have lower GPU usage - max 85-90% only. 2080ti NVlink
thanulee
Thanks a lot Ahmet!
Can someone pin the features of 2020.2 standalone in the 1st post so we know what is and what isnt added in c4d plugin? Just the core ones, would be really helpful.
Many thanks :)
SSmolak wrote:With this version I have lower GPU usage - max 85-90% only. 2080ti NVlink
Please test it enough, all good here! You may have a particular case with a scene or about GPU settings.
