C4D R20 "initializing plugins" issue with Octane 2020
Trakntrak
I just subscribed to Octane Enterprise and installed it but i have this "Initilazing Plugins" issue when launching C4D.
-I only kept c4dOctane-R20.xdl64 in the octane Folder.
-Driver of my RTX 2080 is up to date with Studio driver.
-I tried to delete the otoy-creential file (as well as the otoy-credential backup file) in the octane roaming folder but that did not help.
I'm on C4D R20.059.
When i bring back my old Octane V4 version it works fine.
What am i missing here?
Thanks for your help.
Benjamin
dmipol
You need to update your licenses to 2020, to be able to use S22 or R23:
https://render.otoy.com/shop/upgrade.php
or purchase an Annual Extension here:
https://render.otoy.com/shop/upgrade.ph ... C67-UGAA1Y
V4 is limited to C4D R21.
podpajska
I also have a problem opening C4D with Octane plugin. I copied the right version of Octane into C4D plugins folder and deleted others as said in manual. I tried with different versions of Cinema - R21, S24, R26 and R2023 with different versions of Octane. It is always the same. When i delete plugin Cinema works again. I dont have any other plugins. When I use standalone Octane works normally.
My graphics card is GeForce RTX 3060 (notebook) with the latest driver.
Any ideas?
podpajska wrote:Hi,
Any ideas?
I have written you a Private Message to better check your installation and machine specs.
ciao,
Beppe
