I just subscribed to Octane Enterprise and installed it but i have this "Initilazing Plugins" issue when launching C4D.
-I only kept c4dOctane-R20.xdl64 in the octane Folder.
-Driver of my RTX 2080 is up to date with Studio driver.
-I tried to delete the otoy-creential file (as well as the otoy-credential backup file) in the octane roaming folder but that did not help.
I'm on C4D R20.059.
When i bring back my old Octane V4 version it works fine.
What am i missing here?
Thanks for your help.
Benjamin
C4D R20 "initializing plugins" issue with Octane 2020
You need to update your licenses to 2020, to be able to use S22 or R23:
https://render.otoy.com/shop/upgrade.php
or purchase an Annual Extension here:
https://render.otoy.com/shop/upgrade.ph ... C67-UGAA1Y
V4 is limited to C4D R21.
I also have a problem opening C4D with Octane plugin. I copied the right version of Octane into C4D plugins folder and deleted others as said in manual. I tried with different versions of Cinema - R21, S24, R26 and R2023 with different versions of Octane. It is always the same. When i delete plugin Cinema works again. I dont have any other plugins. When I use standalone Octane works normally.
My graphics card is GeForce RTX 3060 (notebook) with the latest driver.
Any ideas?
Any ideas?
Hi,podpajska wrote:Hi,
Any ideas?
I have written you a Private Message to better check your installation and machine specs.
ciao,
Beppe
