strange shadows around M4 genitals (redness?)
gsfcreator
Hi there, people! :)
I've tried messing around with Ray epsilon, turning some materials in the Gens to invisible...I still couldn't fix that issue. any ideas?
strange shadows around genitals.png (34.53 KiB) Viewed 3707 times
Core I7-8700K, 32RAM, GTX1080Ti, win10
I suggest transforming the gen prop out from the M4 body, so the vertices of the two mesh items do not share the same space.
wimvdb
What i usually do in such a case is to use the morphbrush with a low offset and separate the genital skin from the M4 skin.
Configuration: Windows 11 Pro, I9 12900K, 128GB, RTX 3090, P12 b1029
gsfcreator
face_off wrote:I suggest transforming the gen prop out from the M4 body, so the vertices of the two mesh items do not share the same space.
thx, Paul! I just adjusted the gen's Z to o.oo1 and it solved the problem :)
wimvdb wrote:What i usually do in such a case is to use the morphbrush with a low offset and separate the genital skin from the M4 skin.
Thx, wim! nice "seeing" you again, around :)
Return to “Poser”
