Hi All,
somebody knows if it's possible to bake texture of a high poly model (without unwrapping) for the same low poly model with a custom Unwrapping? I mean some like "BakeTexture" node of Mantra.
Thank you.
Luther
Bake Texture to High Poly to Low Poly
to batch baking you have the substance automation toolkit that was build exactly for this purpose.
https://docs.substance3d.com/sat/sample ... tools-demo
you will not find better path imo. cause if find mantra baking really slower and not as accurate as substance designer.
the only baker that i find better is marmoset but the workflow is very manual and not as good for automation.
Is It possible to use this Python API inside houdini via a python node?
well i have never try, but there is 99.99% chance that it is possible.
Just the shell rop would allow you to do so i guess ? but i thinks using shell ROP might be a little bit old school now ?
Maybe check the TOP ? Or simply ask the question on Od Force, people far more skill than me could give you the best answer.
Cheers
E
Cheers
E
