exported orbx and ocs not being rendered
Moderator: BK
crackfox
this affects only the plugins.
i can render in standalone but not in plugins.
how can i fix this please?
crackfox
i exported from c4d and it worked.
compared the two and matched the nodes.
now it works
If you have an issue with the DAZStudio plugin, can you try to solutions at viewtopic.php?f=44&t=73445, and if that does not work, provide the information requested in that post so that I can assist you.
crackfox
i refer to that faq but cant seem the find the solution there.
the problem, in any case, was that the file is exported with default_render setting node. when i bring in a render target and pipe in the geo node and resave it works.
so my workaround is to open in standalone and replace the last node with render target.
i would still need help exporting animated chracters, the info is sparse.
Return to “DAZ Studio”
