Texture Doesn't Follow Mesh / Joints
darenzd22
Ok so I've definitely decided to bite more than I can chew... I've been learning C4D for the past 3 months, and with each tutorial, I probably felt more confused than before. Recently I decided to try out my first project and create an animation by combining the previous stuff I've learned.
I got a model from sketchfab, rigged it using mixamo, and found a tutorial on how to create a cracked marble material. Unfortunately, I noticed that if I add keyframes to the joints that the material I created doesn't move along (e.g. it looks as if sliding through the model, or basically that it's standing still while the model moves)
I assume this has something to do with projection, but I haven't found any solutions so far, any thoughts?
Here is the project:
https://drive.google.com/drive/folders/ ... sp=sharing
darenzd22
I tried the pin material tag, which I assume is the sticky texture tag. It didn't help me
darenzd22
I tried adding the sticky texture but that didn't help :(
blastframe
I am encountering this problem as well. Is there a way to get Pin Material working in Octane for Cinema 4D?
did you change the projection from UVW / MeshUV to something else?
ciao Beppe
blastframe
bepeg4d wrote:Hi,
ciao Beppe
@bepeg4d, Hi Beppe, I didn't change the projection, but your question led me to consider that my polygon object (a C4D plugin) didn't have a UVW Tag which is apparently necessary for Pin Material to work. Thank you very much for your help! It's working now.
maksoz
You should paint with substance painter no way out. I figured out like this.I have a same problem before
