I have tested the Octane Animation capabilities with a small logoanimation.
Rendering took about 3-4 Minutes / FullHD Frame with my GTX 570 which is much faster then even biased renderengines as Vray and C4D Renderer rendered it on my i7 980X (6x3.33 GHz) CPU.
Conclusion:
Octane is not only a great renderer for Architecture and Productviz but also fast and usable for animations (especially in the direct lighting mode). The only drawback I had was the missing of Object-Motionblur which would have made the scene look even better.
I hope you like my small test!
For more Info just ask!
Cheers Silverwing
Octane Render Logoanimation
- Silverwing
- Contact:
WIN 11 PRO 64 | ASUS X299 SAGE | 1X RTX 4090 3X RTX 3090 | i7 10980XE | 128GB RAM
Very cool!!!
GTX670 4GB, GTX460 2GB, Q8400 2.27Ghz, 6GB RAM
Nice one.
Good work.
Good work.
Realy cool.
Also the demo reel on your website, much stuff i like
face
face
http://vimeo.com/user2509578
- Silverwing
- Contact:
@ 3form:
Thank you very much!
@ [gk]:
Thanks for the suggestion.
But the post motion blur mostly doesn´t match my quality standards!
Thank you very much for your opinion.
What I´m trying to say is that 3D M-Blur has the best Quality without artifacting. And every other solution comes with a disadvantage that I´m not willing to pay!
@Refracty:
Thank you very much. Appreciate it!
@face:
Thank you! And also thanks for liking my demoreel!
Thank you for all your comments!
Cheers Silverwing
@ [gk]:
This is right but it only works if you have no DOF in the renders. It looks really weird if the MB is sharp at edges when the DOF has blured them in the beauty pass!You can render a motion vector pass from your host app and use it to drive motionblur.
Again right. But they loose grip at flat surfaces like these in my animation besides they produce artifacts when things are moving fast and in different directions.You can also use post vector lookup blur engines.
@Refracty:
@face:
Cheers Silverwing
- infernoVFX
Love the animation, even without the motion blur it looks just fine to me ....
Asus rampage III extreme, i7 950 OC 4GHz, Kingston 12GB DDR3, WD VelociRaptor 300gb, 2x WD Black 640gb, Asus ENGTX 580//
Gigabyte P67A UD7 B3, i7 2600K OC 5GHz! Mushkin Blackline 16GB DDR3, OCZ vertex3 SSD, WD black 1TB, MSI GTX 580 lightning OC 993MHz!
very clean anim done...excellent work mate !!
3rdeye
3rdeye
