UVMAP node in Octane 4
Geno
Hi.
I upgraded to Octane 4 and LW 2019 recently and for some reason UVMAP node is not working for me. Is there any way to apply the automatic sizing or T texture from LW? What is the best approach to do this?
pixym
Try to change the UV set number.
Work Station : MB ASUS X299-Pro/SE - Intel i9 7980XE (2,6ghz 18 cores / 36 threads) - Ram 64GB - RTX4090 + RTX3090 - Win10
Net render : MB Asus Pro WS W790E-SAGE SE - XEON - 128GB - 2 x RTX 3090 - 3 x RTX 2080TI
Geno
Thank you pixym. So do I have to UVmap everything in my scene to get it right? no more box or spherical mapping with autosize option?
pixym
If you do not want to use UV, you can use the projection node.
Geno
Thanks pixym. I´ll give it a try with that node and LiveDB materials.
Best regards.
smount1
With the UV Map node connected to the Normal input on the root Surface node, set the Map Type to the Lightwave T Color Layer.
Geno
Thank you smount1. I use to do that in LW 2015 with Octane 3 and worked. Now the I upgraded both, this feature is not working for me anymore.
Return to “Lightwave 3D”
