I have two 2080 in NVLINK and they fail when I have RTX on big scenes. What kind of steps can I take to troubleshoot this?
I have freshly upgraded 456.36 drivers with a clean install. 64 GB of RAM. Using Octane 2020.1.5
I can render no problem with RTX off.
RTX Makes my GPUs fails: guide to troubleshooting?
when RTX on, it takes more Vram than it is off, as you mentioned the scene is a big one,
perhaps your scene is exceed your Vram capacity(you can find the info for vram using at the bar below the rendering viewport), in this case you cannot turn RTX on,
Supermicro 4028GR TR2|Intel xeon E5 2697 V3| windows 10| revit 2019 |Titan V+ Quadro GV100+RTX 2080 Ti
afaik RTX and Ooc are not working well together means you cannot turn both on at the same time, till to current version,
It is heard this issue may be resovled in the version of 2020.2...
