I am currently testing some ways to archive god rays... I had some limited success with adding a scatter medium to the environment, I saw many tutorials for cinema which would use an fog object instead...
is this supported by the Rhino plugin somehow?
thanks for any feedback
Andreas
Fog object in Rhino ?
1 x 4090 GTX, 1 x 3090 GTX
http://www.v-cube.de
Hi Andeas
You can just use a cube that contains the fog (ie. assume a material to the cube with a scatter node attached). However I think you get much better results using the Environment Medium pin, and using a large Medium Radius value.
thanks Paul, I will try out both approaches, you are probably right,
it is mostly that I don´t have much experience with this and the parameters are very cryptical to me...
best
Andreas
best
Andreas
i´s slowly coming along...
by the way, thanks again for supporting the RN plugin, this scene was entirely done with it... for vegetation and especially grass this is a complete gamechanger!!!
best
Andreas
best
Andreas
Wow - looks amazing!
