cant use denoiser in viewport - waiting for image
crackfox
hi all,
if i choose the preview denoiser beauty pass, turn on using octane layers, activate the denoiser beauty box, the viewport is stuck on waiting for image.
edit: this was very frustrating, but turns out i needed to turn on camera imager for the denoiser to actually work when looking thru the camera.
makes sense ofcourse, but is there a reason camera imager is not on by default? i know now to double check on this but i was under the impression its always on...
also turning camera imager on one camera seems to turn it on on all. other parameters can differ, camera imagers is apparently global, so why not make it on by default.
the log is still strange. this is an example i get:
Tried to access pin via an invalid ID P_AI_LIGHT_STRENGTH (385)
Tried to access null node pin
Can't read float from static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 00007FFB75C07280)
Can't write float to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 00007FFB75C07280)
Could not refresh authorization token. Will retry in 60s
it keeps repeating this, what does any of this means?
i am having other difficulties but will separate the posts.
linograndiotoy
I have Camera Imager on by default. You can as well, just activate it in your startup scene and "Save Startup File".
crackfox
that i will probably do, but it could have spare me quite a few hours having it hardcoded in.
now i know, but there will be definitely others with similar issue. having it on out the box will save them and you time.
in the end, this is the sort of thing that makes blender integration less than optimal.
there are far more important issues i wrote about so see you in the other threads..
crackfox
for anyone finding this thread with the autorisation token issue - it fixed itself by having a reinstall of the server and octane blender.
Return to “Blender”
