DOCUMENTATION ADDENDUM: Rendering Alembic Files
Hi
There have been some improvements in rendering .ABC files in release 2020.1.5.163.
To render .ABC files you will need a Modo Alembic File item (specifying the .ABC file to load), and a Modo Alembic Mesh item.
The Alembic File item must have Geometry Scale set to 1. If you need to scale the item, use the Alembic File Transform->Scale.
The Octane Material applied to the .abc file will be that assigned as teh Default material in the Shader Tree.
kostache
Hi Paul,
great news - thanks, but I couldn't make my scene to be rendered (embedded). Could you, please, check it and tell me where I do something wrong?
Thanks in advance,
Konstantin
hardeningunit.7z
(17.42 KiB) Downloaded 2453 times
kostache wrote:Hi Paul,
Thanks in advance,
Konstantin
Hi Konstantin - that archive is missing the .abc file.
kostache
Hi Paul
Sorry!
hardeningunit.abc
(191.87 KiB) Downloaded 2464 times
Thanks Konstantin
That scene is rendering in Octane in version 2020.1.5.163, however the locators the ABC file is parented to are not being applied. I will look into how this could be implemented. It may not be simple, so may not make the next release.
spigolo
I'm trying this but without success.
I'm importing a phoenixfd animation. I see it well in modo but no way to render it in octane...
3dsign studio
Advanced visual communication
http://www.3dsign.it
spigolo
What I do wrong?
In Modo it works...
3dsign studio
spigolo wrote:What I do wrong?
In Modo it works...
Can you PM me the .LXO and the .ABC file please?
spigolo
I have sent the file and scene.
3dsign studio
Hi
I downloaded your file. Forgive me if I do not understand how you have setup your scene, however the KITCHEN.ABC file does not appear to be rendering in the Modo renderer. It's the PhoenixFDLiquid001 that renders, which is not an ABC file. I loaded KITCHEN.ABC into Octane Standalone, and it did not seem to render there either.
Return to “Foundry Modo”
