Export Area Quad Light fails
Hesekiel2517
Hey Paul, i tried to export some Quad Lights as Orbx, but an error occurs: Tried to access pin via an invalid index 1 / Tried to access null node pin.
In my Scene loading the resulting file as a proxy crashes modo. In a Testscene i can't reproduce the crash, but the error is listed in the log.
Edit: I can save the orbx without error via the showNodegraph Command. The Error in Modo stays the same, but i can load it into Standalone
Edit2: Creating a Quad Light in Standalone and loading as a Proxy in Modo works though
Hi. OTOY are aware of this issue, and it should be resolved in the next release of Octane.
Hesekiel2517
Hi Paul,
that sounds great! Thank you
Hesekiel2517
Hi Paul,
exporting does work great now, but using these orbx files as a proxy insta-crashes Modo. Is there anything you can do about it?
Hesekiel2517 wrote:Hi Paul,
Can you send me an ORBX which crashes Modo when used as a proxy please?
Hesekiel2517
Oh, I'm sorry, of course
Octane_Crash.zip
(31.03 KiB) Downloaded 202 times
Thanks. The crash is happening inside Octane, so I have asked if an OTOY dev can take a look at the issue.
Hesekiel2517
Nice! I was a little afraid this was working without a crash on your side :)
Return to “Foundry Modo”
