Hey Paul, i tried to export some Quad Lights as Orbx, but an error occurs: Tried to access pin via an invalid index 1 / Tried to access null node pin.
In my Scene loading the resulting file as a proxy crashes modo. In a Testscene i can't reproduce the crash, but the error is listed in the log.
Edit: I can save the orbx without error via the showNodegraph Command. The Error in Modo stays the same, but i can load it into Standalone
Edit2: Creating a Quad Light in Standalone and loading as a Proxy in Modo works though
Export Area Quad Light fails
Hi. OTOY are aware of this issue, and it should be resolved in the next release of Octane.
- Hesekiel2517
Hi Paul,
exporting does work great now, but using these orbx files as a proxy insta-crashes Modo. Is there anything you can do about it?
Can you send me an ORBX which crashes Modo when used as a proxy please?Hesekiel2517 wrote:Hi Paul,
- Hesekiel2517
Oh, I'm sorry, of course
- Octane_Crash.zip
- (31.03 KiB) Downloaded 195 times
Thanks. The crash is happening inside Octane, so I have asked if an OTOY dev can take a look at the issue.
- Hesekiel2517
Nice! I was a little afraid this was working without a crash on your side
