animating with displacement modifier - rendering same frame
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
womble
I'm using latest free tier blender "OctaneRender® Prime for Blender" Blender_Octane_Edition_2020.1.3_21.11_stable.exe
I've discover what I think may be a bug.
I'm using default cube
add an empty to scene
add displace modifier to cube with Texture Coordinates
add a texture such as clouds to the displace modifier and set Texture Coordinates to Object and Object: set to Empty
animate the empty (360 on z axis in my case)
All looks good in viewport - the cube gets displaced over time.
But when I render I just get the same frame rendered out.
Screenshot and file...
http://skippingcricket.com/tmp/displaceBug.blend
Regards
Andy
SW: Octane 1.54 | Win 10 64bit | Blender 2.78 HW: GTX 580 1.5GB | GTX 780Ti | i5 2500K (OC @ 4100mhz) | 8GB RAM | Asus P8Z68-V LX Drivers: 306.97
linograndiotoy
You should set the Object Type to Reshapable, from the Object Properties/Octane Settings tab.
womble
Ahh perfect! That worked a treat thx
Return to “Bug Reports”
