Normal map is not correct in Octane
seker800
I baked the normal map of the 3D model in 3dcoat, and I imported the normal map into Substance Painter, there is no problem.
However, the normal map is not displayed correctly in Octane.
test.obj
(3.74 MiB) Downloaded 192 times
galleon27
The normal map is displayed correctly. You can even see the errors in the Normal map texture that you attached. Your bake is not good.
Here is a screenshot of your OBJ from Houdini Viewport. You can see the same thing happening. I'm guessing your normals didn't export the way you wanted them.
Win 10 64bit // GTX 4090 + GTX 3090 // 5900x // 64GB // SideFX Houdini // C4D
seker800
galleon27 wrote:The normal map is displayed correctly. You can even see the errors in the Normal map texture that you attached. Your bake is not good.
I don’t really understand the setting of normal maps. Is there a different standard for normal maps?
As a result, it is available in some software and unavailable in other software.
seker800
Solved, I need to invert the green channel
linograndiotoy
seker800 wrote: I don’t really understand the setting of normal maps. Is there a different standard for normal maps?
Yes, you have 2 standards, DirectX and OpenGL. And yes, they only differ in the way they're dealing with the Y (Green) channel, as you discovered.
Return to “Blender”
