orbx displacement map -> strange circlelines
Unreal® Engine Integrated Plugin
Moderator: ChrisHekman
lassinger
hi there,
thanks for all your help so far... I'm just starting with Unreal (and Octane in Unreal) and I'd like to continue with it...
I noticed in my scene that in my Landscape Displacement there are strange Circlelines.
The whole scene was imported as Orbx, in Octane Standalone there are no such artifacts...
http://www.larsnaglerworks.com
http://www.behance.net/LarsNagler
http://cargocollective.com/larsnaglerworks
Mac Pro 5.1 :: 3,33 GHz 6-Core Intel Xeon :: Mac Pro Nvidia GTX680 4 Gig :: 32GB :: C4D 13 Studio :: Octane Renderer
OP-1
EvolverInteractive
Adjust your ray epsilon it should go away.
ChrisHekman
EvolverInteractive wrote:Adjust your ray epsilon it should go away.
Good chance this would fix it yes.
Other than that: Are you using orbx proxy import or orbx import and the latest build?
lassinger
i used the 0.36 version and orbx import
OP-1
ChrisHekman
Could you try using the latest build? Also, did changing the ray epsilon work?
viewtopic.php?f=132&t=75267
lassinger
i will try the latest build...
thanks for your help,
i am shure a have a lot more questions in the future... ;)
ChrisHekman wrote:Could you try using the latest build? Also, did changing the ray epsilon work?
OP-1
ChrisHekman
lassinger wrote: thanks for your help,
Please do, Im documenting every feature request.
crackfox
fwiw my 2 cents,
the only format that worked for me was exr.
hdr cannot be loaded into the map slot, others get downsampled.
Return to “Unreal® Engine”
