deep image unreal
Sub forum for bug reports
Moderator: ChrisHekman
mikzhougame
Hello,
I'm trying to output deep image passes in UE 4.24 but the outputs doesn't have deep data or deep passes. I also tried from sequencer as exr and also don't see the deep exrs, just the denoised beauty etc. Is it bugged or what is the proper way of exporting this? Thanks for your help!
Mike
FL4NKey
I have exactly same issue. Cannot figure out how to actually export deep from unreal. In vieport, the render time is definitely much longer with deep enabled, but exported EXRs do not contained any deep data nor there is seperate file for this.
We really need it for compositors.
ivom
we fiddle out how to export single deep frame but not sure how to render whole sequence.
Could someone help please??
Thank you
ChrisHekman
Ill see if I can expose this feature to the sequence renderer.
For now you can use the following workarounds:
- For single frame deep exports you can use the Octane standalone GUI.
- For sequences, you can export to ORBX and use the Octane Standalone batch renderer to export the deep images.
Return to “Bug Reports”
