Hello,
I'm trying to output deep image passes in UE 4.24 but the outputs doesn't have deep data or deep passes. I also tried from sequencer as exr and also don't see the deep exrs, just the denoised beauty etc. Is it bugged or what is the proper way of exporting this? Thanks for your help!
Mike
deep image unreal
Moderator: ChrisHekman
I have exactly same issue. Cannot figure out how to actually export deep from unreal. In vieport, the render time is definitely much longer with deep enabled, but exported EXRs do not contained any deep data nor there is seperate file for this.
We really need it for compositors.
- ChrisHekman
Ill see if I can expose this feature to the sequence renderer.
For now you can use the following workarounds:
- For single frame deep exports you can use the Octane standalone GUI.
- For sequences, you can export to ORBX and use the Octane Standalone batch renderer to export the deep images.
