orbx vdb greyed out - settings reset
Sub forum for bug reports
Moderator: ChrisHekman
crackfox
i have a vdb sequence in the scene aswell as in the sequencer.
seems i need to have one in the sequence to be able to render it.
i often get random crashes relate to vram while rendering, although i have allocate 32gb for out of core usage.
since i can set the frame range to start from where the crash occurred its not an issue.
however, the vdb i have in sequencer after the new start gets greyed out and the material settings i had in place are lost, ie they defer to the default settings.
i am kicking myself not to have made a screenshots of settings, this way i cant really pinpoint the exact same settings and the crash happend mid vdb.
crackfox
a follow up:
the crashes were caused by my ambitions voxel size setting. i pushed it too low.
however even o exit the orbx settings are disregarded. perhaps they revert to the volume setting i had while exporting, but that makes little sense since i need to fine tune it in scene to get the look i want.
hope it can be remedied.
ChrisHekman
Ill check it out why the vdb/orbx resets when entering sequencer.
crackfox
thanks chris,
both the static and animated vdb´s have their settings reset.
it may be related to the sequencer but i an not entirely sure.
the static vdb is indeed in the sequencer because i am keyframing its location...
crackfox
hi chris,
i did some more testing.
any sort of rbx static or animated has the settings reset upon restarting unreal.
Return to “Bug Reports”
