Bump map artefacts
Igor_K
hi Paul , All,
I have noticed sometimes I have artefacts on Bump map. See render below:
You can see (depending on camera angle) that there are some shading/lighting artefacts (edges marked with green).
If we compare to the Polysurface, you can see that artefacts appear directly along surface edges:
BTW, surface was created with TSplines for Rhino5. Is this the core of the problem, maybe??
So, why those artefacts appear?? Is it related in any way to "Shadow terminator" issue ?? or something else??
Attaching Rhino6 file:
surface_test.zip
(1.23 MiB) Downloaded 270 times
Igor
What version of the plugin are you using please?
Igor_K
Paul, I'm using Octane version: 2020.1.0.121 - Enterprise
whersmy
Might be a scene scale issue? Can you check the rayepsilon slider in Kernel?
Octane 2022.1.1 nv535.98
x201t - gtx580 - egpu ec
I didn't get any artifacts when I rendered your scene. I could be a shadow from your environment map.
Igor_K
I tried to adjsut Ray Epsilon slider - no effect on the result, still seeing artifacts.
I've tried with multiple different HDRi . With some of them its less visible (but still present).
Any other guesses?
whersmy
Can you export an .orbx?
Maybe try a 32-bit image? With displacement it can make a difference.
Also the Uv`s are proper, right?
Igor_K
whersmy
orbx attached
surface_test.orbx
(5.04 MiB) Downloaded 342 times
I'm using tri-planar mapping here and Octane noise texture for bump.
whersmy
Looked it into it, and yes, it is weird. It becomes way better visible when using a really small scale noise texture. When using a larger scale (though probably not the user-case) it`s not visible.
I never really had this issue before :geek:
Igor_K
whersmy
Thanks for checking!
Paul, maybe you can share .orbx file with Octane dev team to investigate?? I still not entirely sure whether its Octane issue or geometry issue (like I mentioned, geometry created with tSplines for Rhino5 and its not very "clean" CAD surfacing, more like a " quick concept" quality), so maybe its issue of bad geometry. I just want to know whats casing the issue and how to avoid it in the future.
Thanks.
Return to “Rhinoceros 3D”
