Proxy mesh/viewport mesh for orbx proxy actors
Unreal® Engine Integrated Plugin
Moderator: ChrisHekman
adamnerva
Feature request: It would be very helpful for layout purposes if I had the ability to assign a lower-res stand-in mesh for orbx proxies to aid in scene assembly within the unreal dx viewport. If an orbx proxy actor had a slot to drag in a realtime version of the asset it would allow unreal realtime rendered actors to be swapped out with film res versions in the octane render.
ChrisHekman
Ill check if this is possible.
In the meantime, I think you can already do this. Add a StaticMeshComponent to the orbx proxy actor, and set the component to be hidden in game or editor only.
Return to “Unreal® Engine”
