Bug - Octane Node not connecting
Area for student license holders to post questions and discuss octane.
noaxyz
]Hey guys,
So I have a very basic setup in my octane node editor (Mg color shader -> colorizer -> diffuse)
As you can see here:
However I got this material by copying/pasting from a previous file I had created, and the node material works great however here is what happens if I try to make it from scratch.
Video:
https://www.dropbox.com/s/bi8xpwtg4ikev ... M.mov?dl=0
First you see me trying to setup and it doesn't work, then you see me break one that did work but can't put it back together...
Hopefully this is an easy fix :P
Thank you.
Please, avoid to use any kind of c4d shader.
Instead of the MoGraph Color shader, that works only in simple Instance mode, set your MoGraph cloners to Render Instance, or Multi Instance, and use the Instance Color node instead:
http://www.aoktar.com/octane/InstanceColor.html
You can also use ther Instance Range node:
http://www.aoktar.com/octane/InstanceRange.html
ciao Beppe
