I tried to set it up by creating a plane that emits particles. Then in the "Object Data Properties" panel I enabled the Octane Sphere Attribute. But all it did was to place the spheres on each of the plane's vertices and did not apply it to the particle system. Are we still limited with only using objects with these systems? Thanks,
Jason
[21.7] Can you use the sphere primitive for particle system?
- linograndiotoy
Right now is not possible.grimm wrote:I tried to set it up by creating a plane that emits particles. Then in the "Object Data Properties" panel I enabled the Octane Sphere Attribute. But all it did was to place the spheres on each of the plane's vertices and did not apply it to the particle system. Are we still limited with only using objects with these systems? Thanks,
Jason
That's been requested anyway and it will be implemented in a future build.
- linograndiotoy
It will be implemented very soon!grimm wrote:Thanks Lino, it's good to hear that it's on the list.
Jason
