RealTime Displacement Issue
barokt
I'm using 2020.1_RC4 version in Cinema 4d R21 Windows 10.
I have 2x2080ti, 9900K CPU an 64GB RAM in my system.
NVIDIA Studio Driver Vers.442.92
My problem is:
When I try to use surface tools in my geometry like grab, smooth tools I cannot get realtime IPR update in my system,
I saw some tutorials in YT in that tutorials they use that tools with realtime IPR update.
I put explanation video in attachments for more info about situation.
Thank you in advance.
https://vimeo.com/411343175
do you have “Synchronized on geo update” option active, in c4doctane Settings/Other panel?
Are you working with Texture or Vertex displacement?
What is the resolution of the Displacement texture?
Have you installed Standalone, at least once, on that machine?
ciao Beppe
Can you see updates if you move any objects?
barokt
Hi, thank you,
- Yes, Geo Update is open (my first check)
- Displacement texture 4k sometimes 8k but it doesn't matter i try both resolutions.
- I assume i didn't install standalone in my computer.
Thank you again.
barokt
Yes i get updates move objects, and i try empty plain no texture just 100x100 subdivision results are same,
ipr won't refresh
When i move objects ipr working correctly
But any subdivided surfaces even cube, plain, torus not working.
I send new ss.
By the way i just realize
if i make changes with plain surface nothings happen
but in same time when i take cube and change cube surface ipr refresh and make first displacement which is plain .
Some kind of priority issue i assume??
Thank you....
show us all parameters from Settings/others section
barokt
There you go.
Thank you, are you in Turkey right now? :)
barokt wrote:There you go.
Yes I'm! You can send me PM for help. I don't see anything wrong, and tested it works well on me.
Try with a clean layout and without installed plugins as RS,etc..
