Cinema4D version 2020.1-RC4 (ReleaseCandidate) 21.04.2020
Hi all,
This is the latest of the plugin with release candidate of 2020.1-RC4 SDK. This means that this release contains all features planned for the stable build once it is released but we may still go through more iterations to solve any issues as required. Please be aware this is still not a stable release so please do not use this for production purposes Any feedbacks are welcome for development and fixing the issues. Enjoy it!
This is the matching Standalone: OctaneRender™ 2020.1-RC4.
Make sure to use a NVIDIA Studio driver with version at least 435.80 for Windows or 435.12 for Linux to enable support for RTX hardware acceleration. There are no OSX drivers that currently support RTX.
1- Use NVIDIA STUDIO drivers, not Game Ready versions. If you have stability issues try different drivers, some of them could cause instability issues. Do a clean install while doing this to be sure previous files completely removed.
Changes of 2020.1-RC4
- Fix for wrong display for some renderpasses with HDR linear/aces tonemap type, also tonemap parameter is a part of scene anymore
- R22 compatibility for R21 build
2020.1-RC4 Standalone fixes/changes that related to Renderer and plugin
Bugfixes:
- Fixed a few scenarios causing CUDA errors after some scene updates.
- Fixed an issue with recent NVIDIA drivers that would cause materials to not to be properly assigned to some instances when using RTX.
- Fixed object layer and material maps so they also work with the new light node types.
- Fixed some scenarios which would cause Octane to not to be able to reach any server due to invalid Windows proxy settings.
- Fixed crash happening during startup on OSX when a proxy is configured in the OS settings.
- Fixed case in which compilation of invalid meshes would result in an unhandled exception.
- Fixed CUDA error when layered materials would exceed the maximum number of layers allowed.
- Fixed CUDA error happening with some mediums with zero scattering values.
Improvements:
- Improved sampling of scattering media with saturated scatter and absorption spectra.
- Mitigated appearance of fireflies in mediums with a highly wavelength-dependent scattering radius.
WINDOWS ENTERPRISE BUILD (R15-R21)
https://render.otoy.com/customerdownloa ... C4_win.rar
WINDOWS SUBSCRIPTION(Studio) BUILD (R15-R21)
OSX ENTERPRISE BUILD (R15-R21)
https://render.otoy.com/customerdownloa ... Macosx.zip
OSX SUBSCRIPTION(Studio) BUILD (R15-R21)
Requirements:
-You'll need to update your Cinema 4D to latest versions(R16.050, R17.053, R18.057, R19.053, R20.057, R21.115). Otherwise, the plugin will not work and not appear in menus.
-Nvidia drivers at least Nvidia Studio Drivers(minimum 435.80) and be careful with latest Game Ready drivers which can cause cuda errors. Stay with stable one for you.
-Cuda 9.1 driver for OSX.
ONLINE HELP MANUAL
To use OFFLINE version of manual from plugin
Download following package and extract to Cinema4D/plugins/c4doctane/manual
https://render.otoy.com/plugindownloads ... p-html.zip
V3 SAMPLE SCENES SET(make a request if you need any specific sample)
https://render.otoy.com/plugindownloads ... scenes.rar
See this topic for some partial samples: viewtopic.php?f=85&t=53989
CINEMA 4D TUTORIALS SECTION: viewforum.php?f=87
CHANGE LOG: https://docs.otoy.com/#60Change%20log
Installation
Ex. if you have Cinema4D R18.0, keep only "c4dOctane-r18.cdl64" and delete c4dOctane-r17.cdl64, c4dOctane-r16.cdl64, c4dOctane-r15.cdl64, etc..
Cinema 4D Release 15: c4dOctane-r15.cdl64 or c4doctane_R15_demo.dylib
Cinema 4D Release 16: c4dOctane-r16.cdl64 or c4doctane_R16_demo.dylib
Cinema 4D Release 17: c4dOctane-r17.cdl64 or c4doctane_R17_demo.dylib
Cinema 4D Release 18: c4dOctane-r18.cdl64 or c4doctane_R18_demo.dylib
Cinema 4D Release 19: c4dOctane-r19.cdl64 or c4doctane_R19_demo.dylib
Cinema 4D Release 20: c4dOctane-r20.xdl64 or c4doctane_R20_demo.xlib
Cinema 4D Release 21: c4dOctane-r21.xdl64 or c4doctane_R21_demo.xlib
Kalua
Thanks, Aoktar!
Testing it now!
C4D 2025.3.3 Octane v1.9.4 // Octane SA 2026.4, Windows 11 Pro, X399, AMD TR 2950X, <<2 X 3090 + NVlink>>, 128 GB RAM, Corsair 1500i - NVIDIA SD 610.62
Octane User since V1 Beta
VVG
Win 10x64, AMD 1950x 16C/32T, RAM 32Gb, RTX 3060x3
Octane-for-C4D(R23.110)2021.x.x, Cycles4D, Centileo. Nvidia 472.47 STUDIO
zoppo
This one has the same problem / bug as the 2019 version:
Setting an image texture to "Type: float" doesn't change the Vram usage.
C4D 2025 | Win10
Kalua
zoppo wrote:This one has the same problem / bug as the 2019 version:
Hi, zoppo
Where are you getting your Vram usage readings from? Live view window or the Octane Texture manager?
Did you make all tests for every cases? You don't know back processes about the renderer and plugin for image storage and processing, even I don't know the renderer side. So I can't claim that's a bug or problem.
I made a quick test and it looks like working, do you wish to share a better info about problem and way to reproduce it?
a1.mp4
(1.22 MiB) Downloaded 13580 times
frankmci
I'm back to testing 2020, and I'm delighted to see the new node grouping tools. These will be SO helpful.
I'd like to request that the background color of the node name field for the Group Node have better contrast with the text. As it is now, it's nearly impossible to read, and my eyes aren't what they used to be. (While I'm at it, the Displacement and DisplacementMixer node names could use better contrast, too.)
I also noticed that the name of the Group Nodes don't update, and are stuck on "NodeGraph", if you change the name in the Info window. To make it take effect, you have to use Right-Click>Edit>Rename.
Great work, Ahmet. I know you said a while ago that node grouping wasn't going to be easy to implement, but this seems to be working very nicely. Thanks!
Also, since the GroupNode can have multiple output pins (wonderful!) can each pin be labeled with the name of its hidden parent node?
zoppo
aoktar wrote:Did you make all tests for every cases? You don't know back processes about the renderer and plugin for image storage and processing, even I don't know the renderer side. So I can't claim that's a bug or problem.
I didn't, I don't, and why should I?
On the other hand I did show you pictures in the 2019-thread: Pick a texture > put it in an "image texture" node > look at the Octane Texture Mangager's Vram column.
Now change the (RGB) texture's type to float and, according to the Octane Texture Manager, nothing changes regarding the Vram.
"Works" in v2019 and v2020.
So either the "Float" setting has no effect, or the Texture Manager ignores it. I would call that a bug, even without knowing "back processes about the renderer and plugin for image storage and processing". If it's not the plugin not processing the setting, but the underlying Standalone, just pass it on to the Standalone guys, please.
@kalua - That's where ;)
C4D 2025 | Win10
thanulee
Thanks for the update.
Is the autobump issue fixed? Seems like core issue probably.
I ve sent you a scene while ago in slack which was freezing the render at a certain frame. I figured out that eventually this was due to autobump.
If that doesnt ring a bell, i can resend scene private to support?
Let me know Ahmet, thanks a lot!
frankmci wrote:I'm back to testing 2020, and I'm delighted to see the new node grouping tools. These will be SO helpful.
This feature is partially implemented and had to stop working on for improving/fixing other issues. Even I forgot that, thanks for reminding this. I'll try to complete it in next releases.
