Hi all,
This is the latest of the plugin with release candidate of 2020.1-RC4 SDK. This means that this release contains all features planned for the stable build once it is released but we may still go through more iterations to solve any issues as required. Please be aware this is still not a stable release so please do not use this for production purposes Any feedbacks are welcome for development and fixing the issues. Enjoy it!
This is the matching Standalone: OctaneRender™ 2020.1-RC4.
Make sure to use a NVIDIA Studio driver with version at least 435.80 for Windows or 435.12 for Linux to enable support for RTX hardware acceleration. There are no OSX drivers that currently support RTX.
IN ANY CRASH CASE PLEASE DO THESE!!!
If you see CUDA errors follow 1,2,3,4.
1- Use NVIDIA STUDIO drivers, not Game Ready versions. If you have stability issues try different drivers, some of them could cause instability issues. Do a clean install while doing this to be sure previous files completely removed.
2- Check GPU frequency. Overclocking would cause instability issues
3- Check PSU. Insufficient power output would cause instability issues
4- Check the free amount of GPU's VRAM and system's RAM while working. Low VRAM will/may cause CUDA errors. Be aware of some generator objects will have different triangle count in Picture Viewer than Live Viewer. It’s like “editor/render” parameter. Just try to use the same value. Also try to optimize your scene for polygon count, even use smaller images. Try to use Octane texture nodes rather than using C4D texture/shaders.
Alternatively, use V4 and Out-of-core(OOC) function. Increase RAM for OOC and It should not exceed physical RAM amount. Check TDR value and increase if it's necessary.
5- If you see C4D crashes without CUDA errors, then send us bugreport.zip, screen-shots and video capture to show process and crash moment. Also please send us a sample scene in a format of C4D or ORBX to let us investigate and test it. Alternatively, try to delete/hide some objects/materials until crash gone away. If you find what's causing crashes, send us a sample scene to let us for investigating and bring a fix or solution.
Thanks for helping the development by your feedbacks! It’s impossible to quickly catch every case without user feedbacks! It’s the same procedure as other companies do like Maxon/etc...
Changes of 2020.1-RC4
- Fix for wrong display for some renderpasses with HDR linear/aces tonemap type, also tonemap parameter is a part of scene anymore
- R22 compatibility for R21 build
2020.1-RC4 Standalone fixes/changes that related to Renderer and plugin
Bugfixes:
- Fixed a few scenarios causing CUDA errors after some scene updates.
- Fixed an issue with recent NVIDIA drivers that would cause materials to not to be properly assigned to some instances when using RTX.
- Fixed object layer and material maps so they also work with the new light node types.
- Fixed some scenarios which would cause Octane to not to be able to reach any server due to invalid Windows proxy settings.
- Fixed crash happening during startup on OSX when a proxy is configured in the OS settings.
- Fixed case in which compilation of invalid meshes would result in an unhandled exception.
- Fixed CUDA error when layered materials would exceed the maximum number of layers allowed.
- Fixed CUDA error happening with some mediums with zero scattering values.
Improvements:
- Improved sampling of scattering media with saturated scatter and absorption spectra.
- Mitigated appearance of fireflies in mediums with a highly wavelength-dependent scattering radius.
WINDOWS ENTERPRISE BUILD (R15-R21)
https://render.otoy.com/customerdownloa ... C4_win.rar
WINDOWS SUBSCRIPTION(Studio) BUILD (R15-R21)
OSX ENTERPRISE BUILD (R15-R21)
https://render.otoy.com/customerdownloa ... Macosx.zip
OSX SUBSCRIPTION(Studio) BUILD (R15-R21)
Requirements:
-You'll need to update your Cinema 4D to latest versions(R16.050, R17.053, R18.057, R19.053, R20.057, R21.115). Otherwise, the plugin will not work and not appear in menus.
-Internet connection for activation, be sure that C4D and Octane will not be blocked by the firewall and any antivirus software.
-Nvidia drivers at least Nvidia Studio Drivers(minimum 435.80) and be careful with latest Game Ready drivers which can cause cuda errors. Stay with stable one for you.
-Cuda 9.1 driver for OSX.
ONLINE HELP MANUAL
Use embedded help buttons from Octane nodes and windows
To use OFFLINE version of manual from plugin
Download following package and extract to Cinema4D/plugins/c4doctane/manual
https://render.otoy.com/plugindownloads ... p-html.zip
V3 SAMPLE SCENES SET(make a request if you need any specific sample)
https://render.otoy.com/plugindownloads ... scenes.rar
See this topic for some partial samples: viewtopic.php?f=85&t=53989
CINEMA 4D TUTORIALS SECTION: viewforum.php?f=87
CHANGE LOG: https://docs.otoy.com/#60Change%20log
Installation
First, remove all octane related stuff from plugins and the main folder of Cinema4D.
Also, download manual.zip and extract to c4dOctane directory if it's not available in place.
Ex. if you have Cinema4D R18.0, keep only "c4dOctane-r18.cdl64" and delete c4dOctane-r17.cdl64, c4dOctane-r16.cdl64, c4dOctane-r15.cdl64, etc..
Cinema 4D Release 15: c4dOctane-r15.cdl64 or c4doctane_R15_demo.dylib
Cinema 4D Release 16: c4dOctane-r16.cdl64 or c4doctane_R16_demo.dylib
Cinema 4D Release 17: c4dOctane-r17.cdl64 or c4doctane_R17_demo.dylib
Cinema 4D Release 18: c4dOctane-r18.cdl64 or c4doctane_R18_demo.dylib
Cinema 4D Release 19: c4dOctane-r19.cdl64 or c4doctane_R19_demo.dylib
Cinema 4D Release 20: c4dOctane-r20.xdl64 or c4doctane_R20_demo.xlib
Cinema 4D Release 21: c4dOctane-r21.xdl64 or c4doctane_R21_demo.xlib
Cinema4D version 2020.1-RC4 (ReleaseCandidate) 21.04.2020
Thanks, Aoktar!
Testing it now!
Cheers,
Testing it now!
Cheers,
C4D 2025.1.1 v1.8.4 // Octane SA 2026.2, Windows 11 Pro, X399, AMD TR 2950X, <<2 X 3090 + NVlink>>, 128 GB RAM, NVIDIA SD 560.94
Octane User since V1 Beta
This one has the same problem / bug as the 2019 version:
Setting an image texture to "Type: float" doesn't change the Vram usage.
C4D 2025 | Win10
Hi, zoppozoppo wrote:This one has the same problem / bug as the 2019 version:
Where are you getting your Vram usage readings from? Live view window or the Octane Texture manager?
Did you make all tests for every cases? You don't know back processes about the renderer and plugin for image storage and processing, even I don't know the renderer side. So I can't claim that's a bug or problem.zoppo wrote:This one has the same problem / bug as the 2019 version:
I made a quick test and it looks like working, do you wish to share a better info about problem and way to reproduce it?
- a1.mp4
- (1.22 MiB) Downloaded 13530 times
I'm back to testing 2020, and I'm delighted to see the new node grouping tools. These will be SO helpful.
I'd like to request that the background color of the node name field for the Group Node have better contrast with the text. As it is now, it's nearly impossible to read, and my eyes aren't what they used to be. (While I'm at it, the Displacement and DisplacementMixer node names could use better contrast, too.)
I also noticed that the name of the Group Nodes don't update, and are stuck on "NodeGraph", if you change the name in the Info window. To make it take effect, you have to use Right-Click>Edit>Rename.
Great work, Ahmet. I know you said a while ago that node grouping wasn't going to be easy to implement, but this seems to be working very nicely. Thanks!
Also, since the GroupNode can have multiple output pins (wonderful!) can each pin be labeled with the name of its hidden parent node?
I didn't, I don't, and why should I?aoktar wrote:Did you make all tests for every cases? You don't know back processes about the renderer and plugin for image storage and processing, even I don't know the renderer side. So I can't claim that's a bug or problem.
On the other hand I did show you pictures in the 2019-thread: Pick a texture > put it in an "image texture" node > look at the Octane Texture Mangager's Vram column.
Now change the (RGB) texture's type to float and, according to the Octane Texture Manager, nothing changes regarding the Vram.
"Works" in v2019 and v2020.
So either the "Float" setting has no effect, or the Texture Manager ignores it. I would call that a bug, even without knowing "back processes about the renderer and plugin for image storage and processing". If it's not the plugin not processing the setting, but the underlying Standalone, just pass it on to the Standalone guys, please.
@kalua - That's where
C4D 2025 | Win10
Thanks for the update.
Is the autobump issue fixed? Seems like core issue probably.
I ve sent you a scene while ago in slack which was freezing the render at a certain frame. I figured out that eventually this was due to autobump.
If that doesnt ring a bell, i can resend scene private to support?
Let me know Ahmet, thanks a lot!
This feature is partially implemented and had to stop working on for improving/fixing other issues. Even I forgot that, thanks for reminding this. I'll try to complete it in next releases.frankmci wrote:I'm back to testing 2020, and I'm delighted to see the new node grouping tools. These will be SO helpful.
