Turn off Alpha Shadows for one object
Banti
Hello everyone,
is it possible to turn off the alpha shadows for specific objects only? My characters hair for example eats render time like crazy because of the shadows the opacity map casts. If i turn of alpha shadows in the render settings it is way faster but it affects other objects too obviously. So is there a way to only make the hair not cast alpha shadows?
unfortunately opacity maps are a killer for any Path Tracing renderer, so the best way is to avoid to use them as much as possible.
In 2020.1 now we have a new Hair material that works great with spline hair objects, have you tried it:
viewtopic.php?f=33&t=73237
ciao Beppe
Banti
bepeg4d wrote:Hi,
ciao Beppe
I did try the new Hair material and i really like it but i thought i still have to plug my opacity map in there?
Guess i have to look at it again.
Also i found out that the opacity map my hair uses is just way too "detailed" or lacked contrast, i guess you know what i mean. I increaded its power to about 3 and the render time was cut in half :)
But i will take a closer look at the new hair material surely.
Thank you
