Freeze at last material convert in LV
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
moebius
Hi
A. win10
B. 2x GTX 1080 Ti
C. 11 GB
D. 26.21.14.3186 Nvidia 431.86
E. not installed
F. 2019.1.5-R3
G. no
H:
bug report: https://we.tl/t-8MlBF8peRH
I have a big scene. Now, if I start the LV, C4D freezes when LV says:
orange font in left upper corner: "Export Material convert mat: "then i says the Name of the last Material I have in the Mat Window"
Sending a scene is a big plus. Otherwise try to find the reason. Delete some parts in scene until render start and defi e what's going on! Thanks!
After checking your bugreport, I can say you have something like C4D SHADER in materials. And it's crashing on multi-processing while doing a shader to texture conversion. Always try to don't use C4D shaders as much as possible.
moebius
thanks! I will look at that!
Btw what happens if you delete TEXCACHE directory?
c:\Users\USERNAME\AppData\Local\OctaneRender\cache\texCache\..
moebius
did not help, I tried it before.
(did help btw for drag'n'drop images from explorer into Node editor. That was another issue.
moebius wrote:did not help, I tried it before.
It was the issue I've faced on your scene. Now it's working well on me. Do you still have problems?
Return to “Bug Reports”
