Freeze at last material convert in LV
Forums: Freeze at last material convert in LV
Sub forum for bug reports
Moderator: aoktar
C. RAM Capacity (i.e. 6 GB)
Postby moebius » Tue Apr 14, 2020 9:23 am
moebius Tue Apr 14, 2020 9:23 am
Hi
A. win10
B. 2x GTX 1080 Ti
C. 11 GB
D. 26.21.14.3186 Nvidia 431.86
E. not installed
F. 2019.1.5-R3
G. no
H:
bug report: https://we.tl/t-8MlBF8peRH
I have a big scene. Now, if I start the LV, C4D freezes when LV says:
orange font in left upper corner: "Export Material convert mat: "then i says the Name of the last Material I have in the Mat Window"
moebius
Re: Freeze at last material convert in LV
Postby aoktar » Tue Apr 14, 2020 11:57 am
aoktar Tue Apr 14, 2020 11:57 am
Sending a scene is a big plus. Otherwise try to find the reason. Delete some parts in scene until render start and defi e what's going on! Thanks!
Postby aoktar » Tue Apr 14, 2020 12:40 pm
aoktar Tue Apr 14, 2020 12:40 pm
After checking your bugreport, I can say you have something like C4D SHADER in materials. And it's crashing on multi-processing while doing a shader to texture conversion. Always try to don't use C4D shaders as much as possible.
Postby moebius » Tue Apr 14, 2020 12:45 pm
moebius Tue Apr 14, 2020 12:45 pm
thanks! I will look at that!
moebius
Postby aoktar » Tue Apr 14, 2020 12:58 pm
aoktar Tue Apr 14, 2020 12:58 pm
Btw what happens if you delete TEXCACHE directory?
c:\Users\USERNAME\AppData\Local\OctaneRender\cache\texCache\..
Postby moebius » Wed Apr 15, 2020 10:56 am
moebius Wed Apr 15, 2020 10:56 am
did not help, I tried it before.
(did help btw for drag'n'drop images from explorer into Node editor. That was another issue.
moebius
Postby aoktar » Wed Apr 15, 2020 2:14 pm
aoktar Wed Apr 15, 2020 2:14 pm
moebius wrote:did not help, I tried it before.
It was the issue I've faced on your scene. Now it's working well on me. Do you still have problems?
Return to Bug Reports
Fri Jan 22, 2021 1:44 pm [ UTC ]
