Hello there,
I've been struggling lately to make Octane 2019 work on both R20 and R21. Everything was working fine and suddenly a couple days ago things stopped working at all.
C4D crashes when launching the LV, when using the Node Editor, etc. Basically impossible to avoid the problem so far. I'm getting a bunch of bugreport errors, the most common is this (with some variants):
Critical_Log
[08:09:06] CRITICAL: Method net.maxon.node.interface.nodeslib.724ec285c557822bf8b9d7fab088470b not implemented by NodesLibImpl (requested by file:///C:/Program Files/Maxon Cinema 4D R21/plugins/Redshift/redshift4c4d.xdl64). [object_impl.cpp(2669)] [objectbase1.hxx(427)]
[08:09:06] CRITICAL: net.maxon.nodes.framework : Error while initializing the method table of interface net.maxon.node.interface.nodesystem. [object_impl.cpp(2528)] [objectbase1.hxx(427)]
Any ideas, please? I can downgrade to 4.05 and make things work, but had a ton of work done with the 2019 shading system and this is getting problematic.
Thanks in advance!
Octane 2019 and R21 Crashes EVERY TIME
Which node editor?
It may not be a problem for us. I see Redshift and net.maxon.nodes.framework in your quote. They are not about octane. Could you please share full bugreport.zip and c4doctanelog?
Also what's driver version?
