Octane 2019 and R21 Crashes EVERY TIME
esteban_diacono
Hello there,
I've been struggling lately to make Octane 2019 work on both R20 and R21. Everything was working fine and suddenly a couple days ago things stopped working at all.
C4D crashes when launching the LV, when using the Node Editor, etc. Basically impossible to avoid the problem so far. I'm getting a bunch of bugreport errors, the most common is this (with some variants):
Critical_Log
[08:09:06] CRITICAL: Method net.maxon.node.interface.nodeslib.724ec285c557822bf8b9d7fab088470b not implemented by NodesLibImpl (requested by file:///C:/Program Files/Maxon Cinema 4D R21/plugins/Redshift/redshift4c4d.xdl64). [object_impl.cpp(2669)] [objectbase1.hxx(427)]
[08:09:06] CRITICAL: net.maxon.nodes.framework : Error while initializing the method table of interface net.maxon.node.interface.nodesystem. [object_impl.cpp(2528)] [objectbase1.hxx(427)]
Any ideas, please? I can downgrade to 4.05 and make things work, but had a ton of work done with the 2019 shading system and this is getting problematic.
Thanks in advance!
Which node editor?
It may not be a problem for us. I see Redshift and net.maxon.nodes.framework in your quote. They are not about octane. Could you please share full bugreport.zip and c4doctanelog?
Also what's driver version?
