Cinema R21 shut down
GIOLETS
I've a critical scene that cause me some Render Failure, and I really like to analyze it in order to find the reason of the problem...
But I cannot save Octane Log or the Console message beacuse after about 10 sendond till the render Failure, my Cinema 4d shut down itself.
So my first question, since I have frequently this shut down, if someone could suggest me how to avoid this automatic exit from Cinema.
Some data:
Actually I use Cinema 4d R21.207, NVidia Studio Driver 441.28, Octane 2019.1.5 R3
I'm on Windows 10 Pro, with 64 GB RAM.
2x RTX 2080Ti (used for Octane) + 1 GTX 780 (for GUI).
ASUS WS X299 SAGE
i9-10900x, 96GB DDR4, 2xRTX 2080 TI, ASUS X299 SAGE, Windows 10
http://www.visual4d.it
Only way I know that deleting some content in scene and test it again. It maybe a material specific or a problem by out of resources
GIOLETS
Many thanks for your prompt answer Ahmet, I'll surely try your suggestions.
Anyway I ask if someone had fall into an instantly Cinema4d shutdown and if can suggest me how to avoid it ..
GIOLETS wrote:Many thanks for your prompt answer Ahmet, I'll surely try your suggestions.
Shutdown may mean out of memory or critical level error which cannot be catched by Host Software. I have similar problems if I go heavy with resources usage on scenes.
frankmci
Have you tried the old, "select the parts you need in 3D space (specifically NOT in with the Object Manager) copy/paste into a new, blank scene file" trick? That's usually my first try with a finicky project file and will often take care of the problem. If that doesn't, you can then do the more laborious 50/50 recursive split until you find the culprit.
