Vectron to Volume sample script
jobigoud
This is a dedicated topic for Vectron-to-Volume scripts and feedback.
vectronVolume.lua
(20.82 KiB) Downloaded 312 times
This is a scripted graph for Octane standalone. Right click in the Nodegraph editor and use menu Other > Scripted graph, then "load script from file" and point it to the Lua file.
Let us know if you find issues, have ideas on how to improve the usability or anything else.
Thanks!
VVG
explain, how use lua in cinema4d octane?
Or LUA only for STDL?
thanks
Win 10x64, AMD 1950x 16C/32T, RAM 32Gb, RTX 3060x3
Octane-for-C4D(R23.110)2021.x.x, Cycles4D, Centileo. Nvidia 472.47 STUDIO
Elvissuperstar007
3ds max?
at least some lessons showed, we don’t understand where to load it
Notiusweb
have to comment on this also-
This is a script, not an OSL, so how should this be working in Standalone.
I load up XB3 and then run the script - it does nothing.
I load a scene with a Vectron - it does nothing.
So unsure how to use this in Standalone as well.
Mobo: 1 Titan RTX, 1 Titan Xp
Plugs: Enterprise
jobigoud
Hi, it's a scripted graph. So you right click in the Nodegraph editor and use menu Other > Scripted graph, then "load script from file" and point it to the Lua file.
VVG
jobigoud wrote:Hi, it's a scripted graph. So you right click in the Nodegraph editor and use menu Other > Scripted graph, then "load script from file" and point it to the Lua file.
thanks
How can this be applied in practice?
OSL scripts are also not widely used.
For the average user, picking code is a difficult task.
It would make sense to make a generator converter Geometry-> Vectron (any geometry in Vectron) ?
Notiusweb
Okay!
works!...
Plugs: Enterprise
Goldorak
thanks
We plan to make this a built in node type down the line to simplify integration across all DCC plug-ins.
VVG
Goldorak wrote:We plan to make this a built in node type down the line to simplify integration across all DCC plug-ins.
now 02/10/2020
Half a year has passed
Goldorak
now 02/10/2020
will try to get it into 2020.2 this month but more likely the release right after that.
