Displacement in UE4
Unreal® Engine Integrated Plugin
Moderator: ChrisHekman
DragonMotion
Hello! How do I use Displacement in ue4? I found this guide (https://www.youtube.com/watch?v=D-hM0hPOzz0), but I don't have the "Convert Displacement" option in the plugin setup. And connecting the displacement texture in octane instance does not give results.... :(
EvolverInteractive
Update your version of Octane.
DragonMotion
EvolverInteractive wrote:Update your version of Octane.
I have the latest version. Downloaded the official plugin with the update from 2019-09-26. In UE4, I have the 0.24 BETA version of the plugin.
LV-426
I have the same problem, is there a solution yet?
ChrisHekman
Displacement is partially supported, and subject to limitations. Because of this it is optional. You can turn it on in the plugin settings:
If you cant find this setting, upgrade to the latest version:
viewtopic.php?f=132&t=73883
EvolverInteractive
You guys know just because it doesn't automatically do the displacement for you that, you can still adjust it in the Octane Material. To do a fresh install of the plugin, best practice is to delete, octane plugin in the the Unreal engine folder under plugins, launch unreal without it, reinstall, and you'll be good.
Return to “Unreal® Engine”
