Out of Core is as stable as the orange president
darstellungsart
Hello,
I really try to use Octane as my main render but your OOC implementation drives me nuts.
different stages of ooc:
-some meshes or proxys are missing
-some shader with displacement are just black
-forest pack-objects won't appear
-viewport crashes and tells me to look at the log (out of memory)
-viewport crashes and tells me immediately that it has not enough memory and max crashes with the next try
-max crashes immediately
Every file is a new surprise.
How i'am supposed to work like that or even think that octane is reliable in a production scenario?
I am using the latest driver and software.
2019.1.5
coilbook
darstellungsart wrote:Hello,
2019.1.5
have you tried to increase gpu head room. I agree out of core needs to be fixed
darstellungsart
@coilbook
I increased the headroom to 1024mb but its no reliable solution.
I exported some of my scenes as orbx and the standalone seem to work fine.
paride4331
Hi darstellungsart,
it could depends on the amount of VRAM and RAM in you PC.
Are you using Windows 10 or 7?
Which (and how many) GPUs on board?
Regards
Paride
darstellungsart
@paride4331
hello,
currently, I am using 4x RTX 2080 Ti with a 2990WX and 64GB RAM (non-ECC)
WIndows 10 18362.592
Is there a combination of OS, max and octane which is better suited for OCC?
samsue
2019.1.5
I'm glad my tip is working. :)
samsue
paride4331 wrote:Hi darstellungsart,
Regards
Paride
Hey Paride
This problem is already well known, I myself have reported several times and seen other people complaining.
It's related to how many polys a single object has, something like this... because deleting a tree that I had in the scene works again.
Another solution was to increase gpu head room. (Although it has no relation, second Manual)
You guys have got to stop pushing on the consumer side.
my setup; 6x 2080 Ti (with NVLINK so ... 22GB vram) / 128 GB Ram
related topics
viewtopic.php?f=27&t=73569
has at least three more... ...but I couldn't find it.
paride4331
Regards
Paride
Hey Paride
related topics
Hi samsue,
could you kindly to share your tree issued scene (in pm if you want) please?
Nvlink works on Quadro RTX at the moment.
Please check yuo've installed Nvidia driver 441.66 (studio) and not DHC but standard, keep in mind 441.66 could be game ready and DHC, but it's wrong.
This is Nvidia driver 441.66 (studio) and not DHC:
https://www.nvidia.com/download/driverR ... 5646/en-us
1 Right click the Start button and select Control Panel.
2 Make your way to System and Security.
3 Click System.
4 Click Advanced system settings from the left sidebar.
5 Select the Hardware tab.
6 Press the Device Installation Settings button.
7 Choose No, and then press the Save Changes button.
8 Unistall the Nvidia drivers using [DDU Nvidia unistaller drivers](http://www.guru3d.com/files-details/dis ... nload.html) (safe mode unistall)
9 install the latest Nvidia driver https://www.nvidia.com/download/driverR ... 5646/en-us
Regards
Paride
samsue
Regards
Paride
Hey Paride
related topics
Hi samsue,
3 Click System.
Regards
Paride
1. Besides my... has some more reports inside other topics.
2. We are usingthe current version of nvidia studio
3. I've done that process several times, honestly it never helped. I'll even try again.
- Nvlink works on Quadro RTX at the moment?
- Do you know how the v-ray octane converter material is doing?
paride4331
Return to “Autodesk 3Ds Max”
