Cinema 4D version 2019.1.3 (Stable) 03.11.2019
Hi all,
This is new build with a stable version of 2019.1.3 SDK.
Any feedbacks are welcome for development and fixing the issues. Enjoy it!
This is the matching SDK for the 2019.1.3.
See all new features of 2018/2019 versions.
To use this version, you need a GPU of compute model 3.0 or higher. Support for Fermi GPUs (like GTX 4xx and 5xx) has been dropped. Also, make sure you use a driver of version 419.xx or higher and if you are working on Mac OS that has a CUDA driver installed that supports at least CUDA 9.1.
1- Prefer NVIDIA STUDIO drivers. If you have stability issues try different drivers, some of them could cause instability issues. Do a clean install while doing this to be sure previous files completely removed.
Changes of 2019.1.3 C4D plugin
  • Fix: Timelimit option
  • Improvements in Node Editor, premade nodes for OSL scripts
  • NVLINK fix, devices fixes
  • Fix: crash in combination, osl texture float parameters(without sliderranges) with octane slider type
  • Fix: Some hanging situations of plugin on exit
Changes of 2019.1.3 SDK
  • Overhauled the auto-bump feature of vertex displacement, which fixes multiple issues that were reported. Now, auto-bump works with vector displacement maps as well and you can add an additional bump map on top of auto-bump.
  • Fixed direct lighting kernel looking different to v4 and 2018.1 when fake shadow is used + when a bunch of glossy materials with no diffuse and specular textures are used.
  • Fixed volume rendering in legacy mode (see viewtopic.php?p=369698#p369698).
  • Fixed a small memory leak when rendering is stopped.
  • Fixed wrong handling of extra arguments in the OSL environment() function.
  • Fixed a crash with a very long image file path.
  • Fixed minor bug in OSL compiler which breaks float val[2]; getattribute("camera:clip", val);.
WINDOWS ENTERPRISE BUILD (R15-R21)
https://render.otoy.com/customerdownloa ... _3-win.rar
WINDOWS SUBSCRIPTION(Studio) BUILD (R15-R21)
OSX ENTERPRISE BUILD (R15-R21)
https://render.otoy.com/customerdownloa ... Macosx.zip
OSX SUBSCRIPTION(Studio) BUILD (R15-R21)
R15-res.rar
WINDOWS DEMO-BUILD (R15-R21)
OSX DEMO-BUILD (R15-R21)
Requirements:
-You'll need to update your Cinema 4D to latest versions(R16.050, R17.053, R18.057, R19.053, R20.057, R21.022). Otherwise, the plugin will not work and not appear in menus.
-Updated Nvidia drivers at least Nvidia Studio Drivers(419.x/431.xx) and be careful with latest Game Ready drivers which can cause cuda errors. Avoids to use 418.81.
-Cuda 9.1 driver for OSX.
ONLINE HELP MANUAL
To use OFFLINE version of manual from plugin
Download following package and extract to Cinema4D/plugins/c4doctane/manual
https://render.otoy.com/plugindownloads ... p-html.zip
V3 SAMPLE SCENES SET(make a request if you need any specific sample)
https://render.otoy.com/plugindownloads ... scenes.rar
See this topic for some partial samples: viewtopic.php?f=85&t=53989
CINEMA 4D TUTORIALS SECTION: viewforum.php?f=87
CHANGE LOG: https://docs.otoy.com/#60Change%20log
Installation
Ex. if you have Cinema4D R18.0, keep only "c4dOctane-r18.cdl64" and delete c4dOctane-r17.cdl64, c4dOctane-r16.cdl64, c4dOctane-r15.cdl64, etc..
Cinema 4D Release 15: c4dOctane-r15.cdl64 or c4doctane_R15_demo.dylib
Cinema 4D Release 16: c4dOctane-r16.cdl64 or c4doctane_R16_demo.dylib
Cinema 4D Release 17: c4dOctane-r17.cdl64 or c4doctane_R17_demo.dylib
Cinema 4D Release 18: c4dOctane-r18.cdl64 or c4doctane_R18_demo.dylib
Cinema 4D Release 19: c4dOctane-r19.cdl64 or c4doctane_R19_demo.dylib
Cinema 4D Release 20: c4dOctane-r20.xdl64 or c4doctane_R20_demo.xlib
Cinema 4D Release 21: c4dOctane-r21.xdl64 or c4doctane_R21_demo.xlib
thanulee
Fantastic and very very fast! thank u!
tomsvfx
Thanks Aoktar!
Is that Fix: Timelimit option that thing I asked here?
viewtopic.php?f=85&t=72959&start=30#p371745
tomsvfx wrote:Thanks Aoktar!
yes
nejck
I've said it in the other thread as well but I really want to give credit because it is due... The OSL custom shader implementation is pretty awesome and well executed! Great job with it! :)
nejck wrote:I've said it in the other thread as well but I really want to give credit because it is due... The OSL custom shader implementation is pretty awesome and well executed! Great job with it! :)
Thanks so much! I wish to improve it for usability soon, any advice welcome. I wish to provide some custom folder for example.
tomsvfx
aoktar wrote: I wish to improve it for usability soon, any advice welcome. I wish to provide some custom folder for example.
Node Editor:
Could inherit some usability from Houdini node graph.
1) Currently with right click it opens pop-up windows with node category list and we can choose nodes.
But it would be cool if there was functionality where we can start typing node name as soon as we that windows opens on right click, and display found nodes in one list.
Just check out how Houdini does, its realy cool. Here you can see how you press Tab and it opens node list and can right away start typing and it searches for nodes:
https://vimeo.com/327610819#t=70s
2) Maybe functionality from Right Click also bind to Tab when we are hovering in Node editor, but this shortcut gets realy handy when its possible to do immediate search as described in previous point.
If you can, you can just download free edition of Houdini and click around it network editor, but that's not 100% necessary.
Render layers:
Fix cryptomatte generating different IDs after each C4D restart.
Octane Settings
Octane Settings -> Camera Image
Would be efficient to have boutton that copies settings from selected Camera Tag
pxlntwrk
I really second that :lol:
pxlntwrk.net
divasoft
Yes, right click pop-ups with incremental search would be really cool
khomatech
Thanks guys. Just to be sure - this doesn't support RTX yet, right?
Meg x299 Creation / i9-9920X / 128GB RAM / 2x Asus Strix RTX2080Ti
