Please add Octane HDRS Dome
Elvissuperstar007
https://docs.chaosgroup.com/display/VRA ... +VRayLight
this is a standard feature and octane has no
in glass buildings, black falls into the windows
divasoft
Elvissuperstar007 wrote:Please add Octane HDRS Dome
Я думаю тебя пошлют и скажут просто юзать трансформ, чтоб отмасштабировать карту.
paride4331
Hi Elviss,
creating an infinite plane.
Regards
Paride
Elvissuperstar007
paride4331 wrote:Hi Elviss,
Regards
Paride
infinite plane it is not always convenient, it blocks the landscape, you need a normal usable Dome
as you can’t understand, we still have terrain surfaces and an infinite plane interferes and overruns
all renders have an infinite surface and Dome
paride4331
Regards
Paride
I see, it could have been a quick workaround.
Regards
Paride
Elvissuperstar007
VIDEO
we are faced with this problem, it is solved only by function HDR DOME
J.C
Elvissuperstar007 wrote:VIDEO
You can easily move the hdri map up or down using full transform.
System – Windows 11
Elvissuperstar007
and you vkurse that a black circle forms at the top? after such manipulations
why come up with wheels? if there is a generally accepted function, why octane users cannot use the functions that other renders have
mbetke
Just add a 180° Degree plane with a landscape/city background on it. The sky needs to be cut out with an alpha. Works for yeas now. I used to use the same HDR images with the black ground.
PURE3D Visualisierungen
SSmolak
But how many wasted GPU memory it can generate especially while using 12K and more HDRI maps.
