Please add Octane HDRS Dome
https://docs.chaosgroup.com/display/VRA ... +VRayLight
this is a standard feature and octane has no
in glass buildings, black falls into the windows
- Elvissuperstar007
- Contact:
Я думаю тебя пошлют и скажут просто юзать трансформ, чтоб отмасштабировать карту.Elvissuperstar007 wrote:Please add Octane HDRS Dome
- paride4331
Hi Elviss,
creating an infinite plane.
- Elvissuperstar007
- Contact:
paride4331 wrote:Hi Elviss,
infinite plane it is not always convenient, it blocks the landscape, you need a normal usable Dome
as you can’t understand, we still have terrain surfaces and an infinite plane interferes and overruns
all renders have an infinite surface and Dome
- paride4331
Elvissuperstar007 wrote:paride4331 wrote:Hi Elviss,
I see, it could have been a quick workaround.
- Elvissuperstar007
- Contact:
VIDEO
we are faced with this problem, it is solved only by function HDR DOME
You can easily move the hdri map up or down using full transform.Elvissuperstar007 wrote:VIDEO
System – Windows 11
System – Windows 11
- Elvissuperstar007
- Contact:
and you vkurse that a black circle forms at the top? after such manipulations
why come up with wheels? if there is a generally accepted function, why octane users cannot use the functions that other renders have
Just add a 180° Degree plane with a landscape/city background on it. The sky needs to be cut out with an alpha. Works for yeas now. I used to use the same HDR images with the black ground.
PURE3D Visualisierungen
But how many wasted GPU memory it can generate especially while using 12K and more HDRI maps.
