Denoise Lighting passes
xavier.altius
Hi everyone
I'm using octane V4.
Is posible to denoise the lighting passes like we do with the beauty, diffuse, reflection, etc...?
I tried everything, using a 3rd party plug-in to denoise those passes, but with not a very good result.
Thank you so much.
Raoul
Currently i don't think its possible.
But would be an incredibly useful feature. A lot of us render out seperate light passes to comp with . They're often quite noisy – so if theres anyway to denoise those as well – very useful for Comping.
Currently the only option is to render the whole scene again with all the other lights off.
Aoktar.. any thoughts on the potential for this? I assume its a core functionality ( not plugin)
thanks!
It's not a plugin feature. Don't know is it easy or not to add in the renderer. Every denoising the every extra passes that may requires more ram/vram. It may be the obstacle.
xavier.altius
Then, the only solution is to increase the max samples.
Thank you both for your responses.
